1 - 3 of 3 Posts
So I have an issue with my passenger side window, I changed out my stock door speakers for new speakers and used a jumper harness wire but now my passenger window is stuck in the down position and I no longer have power to my regulator.... anything helps
Window track is clear of all obstacles, I lost all power to passenger window regulator and can not find any cuts or splices in the wiring going to regulator but it is stuck in the down position so I had to take out the bolts that hold it to the regulator in order to use pvc pipe to hold the window up.
1 - 3 of 3 Posts
