1 - 20 of 28 Posts
Discussion Starter #4
hi everybody.
this is my ep3.
i have seen 240whp on a dynapack.
it has stock edm block with geometrical compression 11,3:1 with toda head gasket
hondata k-pro
injen silver cai
rbc ported
spoon throotle body
jdm 4-2upper piece header(because of low compression)
j's racing 70mm RR exhaust
skunk2racing valve spring
skunk2racing limited stage2 protuned cams
that's all folks!!!
NEA SMIRNI panionara.. sorry file , eimouna aposxolimenos... Megalosa athina alla meta to likeio eirtha ameriki kai kolisaaaaaaa
Discussion Starter #8
egw eimai korinthios alla spoydazw athina kai h kopela m einai apo brahami!!!
exw filarakia apo nea smurnh!!!
amerikh poy?
fobero to ep3 man prepei na kanei k gamo to thorybo i exatmisi eixa s2k palia me 70rr k eixa trelathei...niko na erthoume k emeis ameriki les na kolisoume.....
Discussion Starter #13
hey guys.sorry for the Greek conversation ,but i was talking to some Greek friends of mine that live in a foreign country.
as far as the jdm 4-2 header i use it because i have low compression and for better performance at low and midrange rpm.
what do you think about the other components?
how in the world is 11,3:1 a low compression ?
what has an header to do whit your compression if anyting bolt on respond better to a high compression motor and not the other way around
Discussion Starter #15
11,3:1 compression is not a high compression for a k series engine.
also 11,3:1 is the geometrical compression.on psi is lower than that because of the big cams and the high overlap the cams have.
also a header and an exhaust with large pipes with low compression engine loses low range response.that why i am telling you that.
i have tested it some months ago in a friend of mine ep3 and the respond was not the same between those 2 headers.
not a great difference but there was a little bit less response with the big one than the small one.
Discussion Starter #19
seriously i dont tink that you know what ur talking about
PrZ i think you don't understand me at all.
let me ask you sth.
can you put as large pipes on the exhaust as you want even that you don't have enough power?
for example: you have a 2.0litre engine with 250hp.can you put an exhaust that has 80mm diameter of exhaust and a header that is made of pipes of 50mm diameter?
will that thing work right?
wraios file kai egw to diko moy stoy
fredy egrapse 244,5 1stage+rbc
dc sport 4-2-1 kai toda 60mm.
programma by ef9 tuned,injen cai.
ayta ta liga.
sorry of grekklish:eek:
1 - 20 of 28 Posts
