in my opinion you cant beat OEM bearings. I have been looking around and have found ACL bearings in one size. Does ACL just make that one bearing and then have you machine the parts to make the bearing tolerances work on your application?
I have only had bad luck with the ACL bearings. I only use OEM and if I want a better grade then I send the presized OEM bearings out to SwainTech and have them coated.
I should have worded that different.. I will be using OEM bearings. What i was wondering is why when you look around you only find ACL's in one size? Im a firm believer in OEM parts.
1 - 4 of 4 Posts
