1 - 1 of 1 Posts
are you running a manifold vacuum reference to the fuel pressure regulator? If the ECU map is based on fixed fuel pressure and you're artificially decreasing the fuel pressure with manifold reference then you would see massive lean AFRs while operating at partial throttle.
1 - 1 of 1 Posts
