1 - 9 of 9 Posts
i have been reserching and no one has brought up the issue of elevation? does anyone know if this will have an effect on the preformance of the itbs i live in colorado thoghts????
Like scmil said, increased elevation will mean a lower concentration of oxygen, which means less power.
There was a thread on this site not too long ago about this very topic
http://k20a.org/forum/showthread.php?t=36621
I would imagine that ITB's would be harder to deal with at higher elevations because of the tuning they require.
If you live in CO, I would seriously consider F/I. We have the same issue here in Calgary. All motor doesn't cut it up here, really.
Ideally the percentage of the gain wouldn't be any different.
Nothing is harder to "tune" at altitude it's called a barometric pressure compensation as a function of injection
Mapping engines isn;t rocket science.
Having a map sensor to adjust fuel trims is useful if you're between high/low altitutde frequently. If you're running off of a purely TPS based map, then you'll run rich at high altitude if you tune at low altitude and lean at low altitude if you tune at high altitude.
It;s not just useful it's a basic necessity of a good fuel injection system. A properly mapped engine controller should run good in all weather/altitude conditions.
1 - 9 of 9 Posts
