1 - 3 of 3 Posts
Hey guy,
I'm doing a K24 swap in a 2000 Honda civic ( Si Canadian vehicle ) and I'm using an EKK2 hasport engine mounts /w a tegy subframe.
What I was told that you can use eg/dc2 lower control arms and it will bolt up fine. I've tried 92-95 civic lower control arn and doesn't work.
The question I have is, If i'm using a Integra subframe does that mean I will have to use a integra lower control are or what lower control arm will I need to use?
" Each driver has its limit. My limit is a little bit further that other "
In what way doesn't it work? Are you certain the arms were correct type?
Sent from my SM-N950F using Tapatalk
use the matching LCAs to the subframe, in your case integra. They're better as they all have provisions for a sway bar which not all egs do
1 - 3 of 3 Posts
