1 - 20 of 33 Posts
02-05 Civic Si Eibach Pro Kit Springs
Eibach Pro-System kits are designed by our team of suspension engineers and ride control experts to offer the best street performance without sacrificing ride quality. The Pro-System is a precisely balanced combination of dampers, sport springs and bump-stops (secondary springs), designed and tuned to operate as an integrated system.
Eibach Pro-System improves turn-in response, increases cornering speed and reduces body roll.
The famous German magazine—Auto Motor and Sport agreed:
"The Eibach (Pro-System) wins with perfect tuning, secure driveability and dramatically improved handling...It was the only Suspension System in the test that offered surprisingly comfortable road manners."
Eiback is the recognized #1 Choice of Automotive Enthusiasts Worldwide!
Specifications:
EP3 Only
1" FRONT DROP
1.1" REAR DROP
CorSport USA.
Discussion Starter #2
01-05 Honda Civic Eibach Pro-Alignment Rear Camber Arm - (+6.0 To -4.0)
Eibach*Pro-Alignment Rear Camber Arm - Camber +6.0 To -4.0 Degrees Of Adjustment.
Precision Alignment Camber Arm Kit for Maximum Performance
Prevents Uneven Tire Wear
Wider Range of Camber Adjustment-Suitable for Street or Track Tuning
One-Year Warranty
After the installation of either an Eibach PRO-KIT, SPORTLINE spring kit or PRO-STREET, R1, R2 coil-over kit, a vehicle's alignment should always be checked. Once a vehicle is lowered, wheel camber may become excessively negative, meaning the top of the tire is angled inward (toward the center of the vehicle). While some negative camber aids in improving traction and road adhesion, too much can result in compromised handling and accelerated tire wear.
Eibach offers a complete range of PRO-ALIGNMENT kits, which provide a simple, affordable solution to correct excessive negative camber. These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications, but they also allow an experienced chassis tuner to utilize the increased adjustment range to "dial-in" a performance-oriented alignment that uses negative camber to maximize a chassis' true potential. With correct alignment, turn-in becomes more precise and handling becomes gratifyingly crisp and predictable. High-speed stability is also enhanced, making an Eibach PRO-ALIGNMENT kit a necessity for the serious performance tuner.
For the extreme lowering of SPORTLINE and PRO-STREET-S, MULTI-PRO-R1/R2 coil-over applications, look for the alignment kits with a greater range of adjustment. These will be listed below the standard PRO-ALIGNMENT kit in the applications section.
CorSport USA.
Discussion Starter #4
02-05 Civic Si Eibach Sportline Springs
Eibach Sportline is the extreme-performance spring set created for the extreme enthusiast—the one who craves a race-car attitude for maximum street performance—with the lowest possible drop, but with the exceptional ride quality you expect from Eibach.
Engineered with the same care as our Pro-Kit springs, Eibach Sportline springs achieve legendary handling by aggressively lowering your car’s center of gravity, using our precision—engineered progressive spring rates.
By radically lowering your car’s center of gravity, our Sportline springs dramatically reduce squat during acceleration, body roll in corners and nose-dive under braking. By using our proprietary, progressive spring design, our Sportline springs provide the ultimate balance between high performance, extreme lowering and comfortable ride quality.
Specifications:
EP3 Only
1.4" FRONT DROP
1.5" REAR DROP
CorSport USA.
Discussion Starter #8
02-04 Acura RSX Eibach Front And Rear Sway Bar Kit
Eibach ANTI-ROLL-KIT (Both Front and Rear Sway Bars)
Step-3: Essential Part Of The Pro-System-Plus & Sport-System-Plus
Performance Tuned Handling
Further Reduce Body Roll
Precision Engineered for PRO-KIT & SPORTLINE Performance Lowering Spring Kits
Part of the Eibach PRO-PLUS, PRO-SYSTEM-PLUS, SPORT-PLUS & SPORT-SYSTEM-PLUS
Million-Mile Warranty
Complete your suspension upgrade with an Eibach ANTI-ROLL-KIT. While our PRO-KIT and SPORTLINE spring sets are regarded as the primary suspension enhancement components, the Eibach ANTI-ROLL-KIT allows critical fine-tuning of your car's handling characteristics.
Our ANTI-ROLL-KIT reduces body roll through increased design stiffness over stock Sway Bars. The result: increased handling and cornering grip in any performance-driving situation.
Manufactured from cold-formed, high-strength aircraft-grade steel for precision performance, and finished with a long-lasting red powder coat finish, the ANTI-ROLL-KIT comes complete with greased urethane bushings for improved responsiveness and all mounting hardware and instructions for easy installation.
Front: 25mm*
Rear: 23mm*
Footnotes: Front Sway Bar Is Tubular And Non-adjustable/ Rear Sway Bar Is Solid And Non-adjustable.
CorSport USA.
Discussion Starter #10
Specifications:
EP3 Only
1.4" FRONT DROP
1.5" REAR DROP
CorSport USA.
Discussion Starter #11
Specifications:
EP3 Only
1.4" FRONT DROP
1.5" REAR DROP
CorSport USA.
Discussion Starter #19
02-06 Acura RSX Eibach Pro-Street Coil-Over Kit
Eibach PRO-STREET Coil-Over Kit (Height Adjustable Only)
High Performance, Eibach Tuned Coil-Overs
Quick - Adjustable Lowering
Optimal Tuning for Aggressive Performance
One-Year Warranty
Now, using the very same Eibach technology used in the latest Formula 1 car, you can get each corner of your vehicle looking and performing its very best. Eibach's exciting new PRO-STREET-S, stainless steel bodied coil-over spring & damper packages let serious drivers quickly adjust the ride height of each individual wheel.
Eibach ERS Racing Springs and ERD Racing Dampers are used in top-level racing series all over the world. We have used this experience, gained from many decades at the highest levels of International Motorsport, including Formula 1, NASCAR, CART, IRL, Super Touring Car and the World Rally Championship, to now put these technological masterpieces into the hands of performance enthusiasts everywhere.
Front: 1.4" - 2.6"
Rear: 1.4" - 2.6"
CorSport USA.
1 - 20 of 33 Posts
