Wow, that's cool stuff. You don't fill up Ethanol stuff?
Very creative. I’m looking forward to seeing the results. Awd fuel system is a big hurdle to jump.Fuel tank project 😁 pump can be installed in same hole where it orginally is.
Yes I am planning to tune the car for RE85.Wow, that's cool stuff. You don't fill up Ethanol stuff?
Thanks for sharing this experience. What does the R in RE85 stand for?Some dude here tested aluminium with RE85. He had small tank, had RE85 sitting in it for a year, nothing happened to the tank inner surface. After 3 years the liquid started to look dirty.
Thanks for the reply and experience on your side on that 🆙.To cut the chase short. e85 is no problem as long as the fuel is regularly used up.
For winter storage, use low to no ethanol fuels. For motorcycles or lawn mowers, drain the carbs before storage. Completely fill up metal gas tanks before winter storage.
Thanks for the clarification.R comes from Renewable.
Nice progress. Your new fuel cell is growing.Pump can be assembled from the OEM hole inside the car.
Hopefully here at K20a.org.And I post there more anyways
Some pics, the site says very often that cannot upload pics, thats why I post here only one or two pics that I manage to upload. Site says Unable to download, the pics was not what it should be. Dunno why.Hopefully here at K20a.org.
The controlled oxidation during a maybe Type 2 anodization process (Sulphuric based) definitely would be an advantage regarding el. insulation, corrosion resistance and so on.I was wondering should I send the tank for anodizing too.
