41 - 60 of 65 Posts
also dont forget to grab some scrap material to mock up your lines. i just used old coat hangers lol.
What kind of flare is needed to go from 3/16 hard line to AN fitting?
What kind of flare is needed for the prop valve from the oem 3/16 hard line?
flare from 3/16 hard line to an fitting would require a 37 degree single flare with a tube nut/sleeve
flare on the prop valve requires an inverted 45 degree flare. or i use adapters that convert from 10x1.0 inverted flare to -3
if interested in any brake fittings i stock all of them and have everything you will need can make it as plug and play as possible.
if interested shoot me a pm.
What kind of flare is needed to go from 3/16 hard line to AN fitting? single 37 degree flare to -an fittings
What kind of flare is needed for the prop valve from the oem 3/16 hard line?double 45 degree flare for oem lines
opps looks like someone already answered your question. but there you go
im not interested in tucking anything. i want to redo my fuel hard lines (5/16 hard line to 6 AN) and redo a brake line (3/16 hard line) from the prop valve to the brake MC.
is there a tool that allows you to flare both 37 degree and 45 degree that you guys would recommend?
duct tape and zip ties
there is no 45 one. they are all 37 degrees. I asked the same question when I did the teal hatch bay.
Just another area to place a prop valve at.
s2k brake master cylinder assembly. fittings route under the wiper motor, and to the prop valve.
:up:
P.M.W./A.W.S.
Discussion Starter #53
:up:
your work screech?
Different but it seems like it would be more of a pain routing the lines to the rear wheels if the proportioning valve was under the cowl.
when there's a will, there's a way :eek:j:
P.M.W./A.W.S.
Discussion Starter #55
Here's a link to El father's old build thread
http://www.k20a.org/forum/showthread.php?t=32840
I then realized you were probably talking about using hard lines, as he used SS braided lines instead.
I'll take a look to see elsewhere, pretty sure this set up has been before however with someone keeping the wiper blades im not sure of
Not a pain really. Just went through exhaust tunnel, behind subframe, up through cabin and to the cowl.
Wiper motors work too, I secured the lines down to the bottom of the cowl area. :up:
kdes, yeah me and a friend did it. Friend has more patience and better tools for flaring.
Cool, good info man thanks :up:
41 - 60 of 65 Posts
