For those of you that have to go through emissions with just an OBD II check engine light test did you guys pass ok? If you have a JDM ECU how did you pass the fuel tank pressure sensor test? What other ECU's will work with the k20a that have the fuel tank pressure sensor (might have to go that route for emissions) I plan to use a kpro ecu but does that mean i can use any other ecu? Any help would be great cuz i live in chicago and emissions is pretty strict.
