1 - 20 of 32 Posts
04-05 Civic Si EBC Redstuff Fast Street Front Brake Pads
High Performance LOWEST DUST rating pads for Prestige imports and faster street driving.
There are TWO reasons our customers love Redstuff, First because they are the lowest dust pad we have encountered by reducing dust by 60-90%. Plus the minimal dust you see is very easily removed with a simple sponge wash as it contains no steel fibre particles as in ALL OTHER pads. Second they brake like an alligator right from cold (as good as Original pads or better) and just get better as they heat up.This material is a Kevlar® fibre based brake compound enhanced with ceramic particles. If you have previously tried EBC redstuff (pre-ceramic compound) this material is light years ahead. It lasts longer, it brakes better and is quieter.
Being a hard wearing pad, bed-in times can be as long as 1000 miles and drivers must be patient until the pad takes up the shape of their disc (brake rotor). This is a truly impressive fast road pad for repeated heavy braking.
It emits far less dust than semi-metallic pads and has been proven to stop a passenger car/sedan/sport compact/hot hatch 13 metres quicker than OEM pads from 100mph/160kph. Features EBC Brake-In surface coating which conditions rotor surface and accelerates pad bed-in. Nominal friction coefficient 0.5 with approx. 50% dust reduction.
Shipping is always included in the price you see inside the 48 lower United States.
CorSport USA.
Discussion Starter #2
04-05 Civic Si EBC 3GD Sport Front Rotors
04-05 Civic Si EBC 3GD Sport Front RotorsEBC 3GD Series Sport rotors are precision-machined using premium-quality castings not only to enhance the performance of your vehicle, but also because they look good. EBC Sport rotors feature wide aperture scraper slots to expel dirt, dust, and gases, and blind drilled holes to prevent cracks and help break down surface gases. When you're looking for performance, turn to EBC.
CorSport USA.
Discussion Starter #4
04-05 Civic Si EBC Greenstuff Street Sport Front Brake Pads
Premium street sport pad for cars up to 200bhp. General spirited street driving.
Designed for premium street driving offering better brake effect up to 600°C (1100°F). EBC Greenstuff has a high initial brake effect and gives drivers confidence from first application of the brake pedal. There is no such thing as a NO DUST pad. The very nature of how a brake works requires that some dust be generated to avoid rotor vibration (shimmying). The EBC pad creates less dust and dust is more easily washed off than most. All pads create more dust as they are bedding in especially if rotors are worn. Nominal friction coefficient 0.55. For heavier faster cars and vehicles above 200bhp we strongly recommend Redstuff which DOES offer much less dust.
CorSport USA.
Discussion Starter #5
02-03 Civic Si EBC USR Slotted Front Rotors
02-03 Civic Si EBC USR Slotted Front RotorsThe narrower multi-slot design of the Ultimax sport rotor and the progressive angle at which the slots are machined creates a quiet running sport rotor that still has benefits of removing gas, dirt, water and debris and maintaining parallel pad wear.EBC has always been honest enough to say that the biggest advantage of slotted rotors is the fact that they promote flat and parallel pad wear rather than allowing ridges to develop on pads and rotors which is typical of “drilled only” sport rotors. By preventing these ridges brakes stay more consistent throughout pad and rotor wear life. Features: Black Zinc Finish Resist Corrosion Narrow Slots Provide Quiet BrakingSlots Ensure Flat/Parallel Pad Wear
CorSport USA.
Discussion Starter #6
02-06 Acura RSX EBC Ultimax Front Rotors
02-06 Acura RSX EBC Ultimax Front RotorsEBC ULTIMAX Blank RotorMade of the finest grade steel with copper for increased thermal conductivity and wear properties. Precision machined to a surface tolerance of less than .0001 mm. An OE quality replacement brake disc.*Price Includes 2 blank rotors*Shipping is always included in the price you see inside the 48 lower United States.
CorSport USA.
Discussion Starter #9
04-05 Civic Si EBC Yellowstuff High Friction Front Brake Pads
Ultra High Friction Pads for Race, Trackday and Street Use.
EBC Yellowstuff is an aramid fibre based brake compound with high brake effect form cold and is possibly one of the first ever compounds that can be used for STREET AND TRACK DRIVING. These pads do not require warm up but do get even stronger under the heat of hard driving. These are not a low dust pad and if your desire is for a low dust premium street use pad, you should consider EBC Redstuff. EBC Yellowstuff is currently produced in two compound versions - DM1846 and DM1793, both of which have been used with some success in racing. HOWEVER, for standard OEM brakes, as fitted to your car, there is no doubt that the DM1793 is getting better feedback, as it is slightly harder, slightly longer lasting and more appropriate for track day driving.When considering full race use, DM1793 has also been a strong favourite, having been used for two years in the Swedish Camaro Cup and at numerous other race events where a stock caliper system is fitted.If using a high efficiency aftermarket race calipers with 4, 6 or 8 piston set ups, the sheer efficiency might allow the use of 1846 compound. DM1846 is currently the choice of the majority of GT3 drivers which are pretty serious competitors.
CorSport USA.
Discussion Starter #18
Discussion Starter #19
04-05 Civic SI EBC Redstuff Fast Street Rear Brake Pads
04-05 Civic SI EBC Redstuff Fast Street Rear Brake PadsHigh Performance LOWEST DUST rating pads for Prestige imports and faster street driving.There are TWO reasons our customers love Redstuff, First because they are the lowest dust pad we have encountered by reducing dust by 60-90%. Plus the minimal dust you see is very easily removed with a simple sponge wash as it contains no steel fibre particles as in ALL OTHER pads. Second they brake like an alligator right from cold (as good as Original pads or better) and just get better as they heat up.This material is a Kevlar® fibre based brake compound enhanced with ceramic particles. If you have previously tried EBC redstuff (pre-ceramic compound) this material is light years ahead. It lasts longer, it brakes better and is quieter.Being a hard wearing pad, bed-in times can be as long as 1000 miles and drivers must be patient until the pad takes up the shape of their disc (brake rotor). This is a truly impressive fast road pad for repeated heavy braking.It emits far less dust than semi-metallic pads and has been proven to stop a passenger car/sedan/sport compact/hot hatch 13 metres quicker than OEM pads from 100mph/160kph. Features EBC Brake-In surface coating which conditions rotor surface and accelerates pad bed-in. Nominal friction coefficient 0.5 with approx. 50% dust reduction.Shipping is always included in the price you see inside the 48 lower United States.
CorSport USA.
1 - 20 of 32 Posts
