161 - 180 of 210 Posts
Discussion Starter · #161 · (Edited)
Thank you for you comments! @Them Witches - I'm coming up on 60 next month, and have been fortunate health-wise. Most of my issues have been results of the many accidents I subjected myself to - surgeries for broken bones, multiple digit surgeries, lower back & neck injuries... However I am now getting arthritis in my wrist, which sucks. My children are adults in their 30's, so I don't have to do that anymore, which gives me time after work most days to chip away at projects.
Today I got a fair bit done on the bracing - added captive nuts, boxed the horizontal support
welds came out clean on this - forgot to photo before primed
Automotive tire Bumper Rim Wood Fender
Bumper Wood Automotive tire Asphalt Automotive exterior
installed that, so I could figure out the center plate
Automotive lighting Motor vehicle Hood Automotive design Automotive exterior
Automotive tire Motor vehicle Red Gas Automotive design
5 M6 sems screws in the plate - the trunk support ties into that, so I need to make sure it's not going anywhere
Shoe Motor vehicle Bumper Red Automotive exterior
came out nice & level with outer panels. I need to figure out a lip seal on the vertical section to keep water out of the trunk. Maybe a flange underneath then thin closed-cell foam.
Hood Automotive lighting Motor vehicle Sleeve Bumper
Motor vehicle Automotive lighting Automotive exterior Bumper Red
added back the vertical support for the trunk stay
Motor vehicle Automotive lighting Automotive design Hood Automotive tire
they have to stay separate since the panels must be independently removeable
Automotive tire Automotive lighting Motor vehicle Hood Bicycle tire
where I left off - had to prime & top coat so I'm not looking at all those obvious bolts. I'll paint it properly before I'm done
Automotive exterior Bumper Motor vehicle Auto part Gas
Discussion Starter · #162 ·
Handwriting Rectangle Schematic Font Parallel
cardboard full panel
Sleeve Motor vehicle Creative arts Automotive exterior Pattern
Wheel Tire Automotive tire Motor vehicle Bumper
after that, I decided I could add the boxed section to the panel I had in place previously, then cut out the backside & add some bits to either upper side as needed
Blue Motor vehicle Wood Automotive exterior Machine
Discussion Starter · #163 · (Edited)
worked on the cover panel a little yesterday
Textile Sleeve Handwriting Font Material property
have to add to the left & right to fill gaps between panels
Automotive tire Motor vehicle Bumper Automotive exterior Gas
Motor vehicle Automotive exterior Bumper Hood Automotive tire
Motor vehicle Automotive tire Wood Bumper Automotive design
Motor vehicle Wood Bumper Automotive exterior Red
Today I worked on the 4-2-1 V-band feed into the flex coupler & cat. Took some time to get the pipe angles right so the cat sits parallel to the crossmember. I'm not doing great with my SS welds at the moment. Had some distortion of the flange. Anyway, shouldn't be enough to be a leakage issue, I used lipped V-bands for this.
Vehicle Automotive tire Motor vehicle Musical instrument Automotive exhaust
I can play with the height of the cat to some extent. I think where I have it currently will work, and it should be a cooler setup than the previous
Automotive lighting Wheel Automotive tire Motor vehicle Vehicle
Wheel Tire Automotive tire Vehicle Motor vehicle
Bus Vehicle Automotive lighting Hood Motor vehicle
Did some more sketching to figure out how to close off the access panel junctions, and a seal between the two braces.
Handwriting Font World Material property Parallel
Moderator
2002 DC5 Type S
wow !!! just wow !!!
Awesome sketches, engineer talent at play with the production fabrication skills of sure craftsman. I really enjoy this thread you are good at what you do and it is a pleasure to watch history unfold.
your sketches look just like my dad's. respect
In Germany they would withdraw street approval for this build faster than you can say "but". Any modifications are great pain in the arse to get approval for. Think of california emissions issues and modifications but covering the entire car down to the tires you mount. You mostly free to choose the color of the paint or wrap. Obviously no cop car paint job or reflective gold or chrome.
Discussion Starter · #166 · (Edited)
Thank you. I usually draw out my ideas, to work out the details as I go along. I'm no engineer though - math was NEVER my strong suit. I'm a public high school Art teacher :)
Was able to get back to the exhaust today, got the right side "U" figured out after several attempts, along with the muffler placement & started figuring out the tailpipe & hanger placement. VBands all over to make setup & component removal easier. I'd like to pin the VBands after, to make installation more precise, not sure how to successfully achieve that.
Motor vehicle Automotive lighting Bumper Automotive exterior Red
Musical instrument Motor vehicle Automotive lighting Automotive exhaust Automotive design
Automotive tire Motor vehicle Rim Automotive design Automotive exhaust
Automotive lighting Motor vehicle Automotive tire Automotive design Bumper
Musical instrument Light Drum Automotive exhaust Automotive tire
Tire Wheel Automotive tire Hood Tread
Hood Automotive tire Vehicle brake Motor vehicle Automotive design
Hood Motor vehicle Automotive tire Grille Vehicle
Discussion Starter · #167 ·
I can't imagine having to work around that. NY is not as loose as many states in terms of requirements, as we have to have annual safety & emissions testing, however, as long as the car 'looks' structurally sound, they are not going to question the type of mods I have made at all, especially if it looks much as it should in terms of layout.
96 civic HX K24a
Art teachers are the coolest cats in the whole school 100% best times I ever had were in that class 😂
Moderator
2002 DC5 Type S
KBuilt is right Indeed art teachers were the best teachers and everyone remembers them throughout their entire life. I still remember my technical engineering and architectural drawing teacher too of four years. I learned all of it before turbo cad came into play and thankful.
Discussion Starter · #171 · (Edited)
Finished up (for the most part) the trunk access / exhaust cover panel
tested my new toy on some scraps of the two gauges SS I used for the panel
Motor vehicle Wood Bumper Automotive exterior Gas
worked from cardboard templates
Wood Gas Tool Scrap Auto part
test fitting the sections
Motor vehicle Bumper Wood Automotive exterior Vehicle
Hood Motor vehicle Automotive lighting Wood Automotive exterior
all welded
Automotive exterior Bumper Motor vehicle Gas Composite material
Some minor additions needed to wrap it up
Rectangle Handwriting Font Parallel Pattern
Hood Automotive lighting Motor vehicle Wood Bumper
Hood Motor vehicle Automotive tire Automotive lighting Wood
drilled the top lip & tapped cross bar for M5 sems screws in the center, and M6 on the outer tabs
Motor vehicle Trunk Automotive lighting Hood Automotive exterior
welded the ears for the right hangers. Can't go any further, the muffler they sent me is the wrong model, I have to wait for the correct one
Motor vehicle Automotive exterior Automotive exhaust Bumper Gas
Discussion Starter · #172 ·
got a few little bits done during the week
SS plate to seal off cross braces
Motor vehicle Bumper Automotive exterior Wood Gas
Motor vehicle Wood Automotive exterior Bumper Gas
worked on the exhaust hanger setup & VBands for the new muffler & tail section
Hood Automotive lighting Motor vehicle Bumper Automotive exterior
Hood Automotive lighting Motor vehicle Vehicle Bumper
Automotive tire Motor vehicle Bumper Automotive exterior Musical instrument
Automotive tire Hood Motor vehicle Tire Automotive lighting
Automotive tire Motor vehicle Bumper Automotive exhaust Automotive exterior
elbow outlet ready to attach new Vibrant 1792 resonator - only about 9" - so it will work in place of my Volvo one that is too long to fit
Musical instrument Motor vehicle Automotive tire Rim Gas
Motor vehicle Automotive lighting Automotive tire Bumper Automotive exterior
96 civic HX K24a
Very nice fab work. 👍 the header and exhaust look great.
Discussion Starter · #174 ·
Welded the trunk brace support tab to the upper brace
Wood Automotive tire Motor vehicle Gas Bumper
After I pulled the cylinder head off my friend's V50,
Motor vehicle Gas Automotive tire Automotive design Auto part
I worked on the resonator / tail section. Finally getting close to done!
test fitting - leveled off the tailpipe a touch after I took this pic
Hood Automotive tire Automotive parking light Automotive lighting Motor vehicle
had to use 3 cut sections of a mandrel bend to get the right angle out the resonator to the tailpipe. Cut most of the straight sections off the resonator, about 1.5" each end
Motor vehicle Automotive tire Automotive design Wood Gas
Still have to seam weld the tailpipe to the resonator - the tip has three welds, that's enough
Automotive tire Bicycle frame Bicycle tire Bicycle fork Motor vehicle
Textile Motor vehicle Public space Automotive design Market
Motor vehicle Automotive tire Red Automotive exterior Auto part
Have to add a hanger to the upper left - either off the resonator/tail pipe, or off the forward edge of the muffler
Motor vehicle Automotive tire Vehicle Automotive exterior Bumper
Discussion Starter · #175 ·
Braces & cover panel complete, just need heat shield material
Finally done with all welding on the exhaust & hangers. Only thing left is a firmer compound upper right hanger, I have several versions & the one I used is a little too soft.
left rear hanger done
Hood Automotive tire Automotive lighting Motor vehicle Wood
Automotive tire Light Hood Motor vehicle Automotive design
plenty of clearance - and no interference for the control arm bolts
Wheel Tire Automotive tire Tread Vehicle
It's close to the 4-2 collector, but not touching. About 1/2" or so, about the same off the rear cross brace
Automotive tire Motor vehicle Automotive exhaust Automotive design Automotive exterior
Definitely happy with the layout. Hopefully it sounds & performs as good as it looks 😁
Tire Wheel Automotive tire Automotive lighting Automotive exhaust
Motor vehicle Automotive exterior Red Rim Gas
Discussion Starter · #178 · (Edited)
worked on the trunk floor panel and the cross brace cover sealing
adding a second frame to give some area for heat dissipation
Hood Motor vehicle Automotive exterior Automotive lighting Bumper
Wood Bumper Gas Automotive exterior Metalworking hand tool
Wood Flooring Gas Mesh Automotive exterior
Automotive lighting Hood Motor vehicle Grille Red
SS cover panel
Bumper Motor vehicle Automotive exterior Red Trunk
1/8" foam
Brown Product Wood Textile Luggage and bags
then carpet. Enlarged original mount holes & used torx screws set into lower frame. No reason to remove this. Closed cell foam beneath.
Vehicle Motor vehicle Automotive exterior Gas Car
Finally figured out how to address the flange for the center cross brace cover. Spot welder did the trick - until I realized I could do it this way, I couldn't see a practical way to join the flange to the original panels without a mess.
Double wall is still thin enough for trunk seal to fit properly here
Hood Motor vehicle Wood Bumper Automotive exterior
I'll use the thinnest closed cell foam I can get away with on the overlap flange - so I'll try 1/16" first
Motor vehicle Hood Wood Bumper Automotive exterior
Discussion Starter · #179 ·
heat shield
foam on flanges
Took the exhaust back off today so I could weld up the factory cross brace ends
Header can be removed without removing the brace insert or top cap, just the trunk cross brace has to come out
Automotive lighting Automotive tire Hood Grille Motor vehicle
rights side cap welded & primed
Motor vehicle Automotive exterior Wood Vehicle Bag
Motor vehicle Hood Automotive tire Automotive exterior Bumper
drivers side partial cap. The inner frame here has multiple reinforcements, so I just added a cap to prevent the inner skin from flexing where the bolts are
Motor vehicle Wood Hood Bumper Automotive exterior
Motor vehicle Wood Art Gas Electric blue
painted
Motor vehicle Wood Automotive exterior Automotive tire Gas
Automotive tire Motor vehicle Wood Gas Automotive exterior
Motor vehicle Automotive exterior Wood Red Gas
