1 - 2 of 2 Posts
I've had this rsx shell for a while and just recently found a donor running civic si(rusted). Is it worth it to transfer from civic si to rsx shell, and what extra do I need to get it working? I saw some forum posts mentioning rsx ecu, throttle body and cable, and transmission speed sensor swap (or I could get a rsx transmission)
96 civic HX K24a
You basically have the parts list down , and yes you could use an rsx transmission the mounting points are the same as the 06-11 SI. You will need an rsx 02-04 engine harness as well ,5 speed will work fine.
1 - 2 of 2 Posts
