1 - 19 of 19 Posts
· Resident Journalist
sup guys, i finally got my swap in, took me a whole day to do everythin and get teh started up and driving on our first try. The Hasport mount kits made it so much more easier and i couldnt beleive the quality of the mounts. I dont care if this mount kit cost slightly more than other companies, this mount set is solid and it comes with all instructions on how to drop in the motor. I heard people complaining about oil pan clearance being too low--- well, from what i see and from what the guys at Access MOtorsports saw, there wasnt any oil pan clearance issues, slightly lower than b-series but nothign to worry about at all. Easy Swap... anybody whos done abseries can do it with no problems at all...... USing Hondata K-Pro made it even easier, the only problem i ran into was freaken headers, i judt didnt have one so i just used the first piece of the header off of a type s and then chopped off the flange and it cleared the rack. Custom header is being made by Hytech exhaust right now... Im only gonna get the best parts now. The motor pullls HAAAARDD>>>. i cant explain how this motor runs.. and its not even tuned technically speaking..I spanked a built gsr in an eg bad...... here are hte pictures if htey work...
· NOR*CAL
i just got mine running earlier this week, and its crazy how hard it pulls compared to the old gsr motor. and the six speed tranny with the 4.7 FD- WOW!
i luv it!
i used the Hasport Wiring harness conversion also with their PnP Subharness too.... it worked out great and on the subharness they all ready have the wires for the ffan switch and thermostat right on it so all you have to do is plug it and that is it... that easy... i have more pictures, and there will also be a whole aticle on how to install this motor into an EG civic in the next OverRev Magazine... it will be a Kseries Issue.
i luv it!
haha. Yeah its hard to describe the pull of these things. We yanked out an itr engine and replaced with a k24/20 and the thing is just....well, MAD. :D
BTW swap looks great!
hi guys, i just got a k20-r full engine swap that includes
Engine
Transmission 6Speed Hydrulic
ECU
Axels
All required cables
All brackets & sensors
Suspensions
Complete wiring harness
Complete intake manifold
Upper tables
Lower tables
Complete bracket table
Shocks & Springs
etc...
i need to know what i need to do to put it in my 93 hb si
please, im really lost right now and i need help!! i know i need the tsx headers...but i dont what and where to get the engine swap kit, i heard the swap kit is like 2g's$ but i need to know what it comes with and where i can get it!!!!
if you guys can help in any way you will help me alot!!! thank! :? :?
1 - 19 of 19 Posts
