all you have to do is slap everything from your rsx on the k24 block, ie. the head, tranny, wiring, just dont touch the block, use everything from the block like the timing chain and cover.. and so on. you can definitely slap the rsx oil pan on there as well.
If you want to change the pump and get rid of the balancing shafts you have to replace them with the RSX pump, pan, and pick up. Depending on which 2.4 block you get you might have to machine the girlde or just the pump itself but only a little minor modification for clearance reasons.
1 - 4 of 4 Posts
