Sounds like that will be pretty neutral, if anything I'd say it might understeer a little. 21mm front bar is a lot bigger than what most autox guys I know are using.
That said, I bet the car will handle sweet with that setup. You just might end up wanting a little more rotation for the tighter turns.
What dampers are you running?
