21 - 27 of 27 Posts
96 civic HX K24a
Wiring and Pinouts
  • Wiring and Pinouts
depin sensor plugs -TrePound
How To: Relays -DB8TypeR
FAQ: How to wire Charge Harness Eg/Dc/Ek -k20jonny
The Definitive K20/24 Sensor Comparison -Froth
Must Read If You Want DIY Wiring!!! -SuperThanh
DIY - Engine Harness Junction Box Delete -screech
Simple wiring harness write-up for EG -kazino42
K20A2 (PRB) / K20A (PRC) ECU PINOUT -nikos
2005 Type-S ECU Pin-Out Help -eK24monster
02-04 vs 05-06 engine harnesses differences -schumacher916
K20A2 vs K20A3 Harness differences -DeMonICRSX
Which o2 sensor can I use?
Primary 02 Sensor Wiring - Check your wiring right here... -[email protected]
Knock Sensor wiring -Paul1985
Injector Resistor Box Install Guide -Oside Jimc
DIY: Injector Clips -k20buildinprogress
How to repin the K24A2 and K24A4 CRK sensor for the K20 Engine Harness -2000Accord5sp
Theroswitch and Temperature Sending Unit -Karcepts
Where do I drill to tuck my main harness? -StErN
Post your Wire tucks/ battery fuse box locations -tibbie 03
What will my Engine Bay look like? Where do the wires go in a tuck? -nikos
DIY: Wire Tuck!!! -SVOboy @ GasSavers.org
Immobilizer wiring - key cylinder -Skyliner
HOW TO: Making a "Secondary Key" Anti-Theft Device -Froth
Shift Light In The A/C Vent pics + vid -Mr Plenty
S2000 cluster swaps
AP2 S2000 Cluster In EG -KJMRide
S2000 Cluster Swap In 92-93 DA Integra -Jeep DA9
S2000 AP1 and AP2 Cluster Swap into 2001+ Civic(EM2) -xproductionz
05-06 tranny with 02-04 ecu harness +s2k -*HAZARD*club
Auto - to - Manual
Auto to Manual K swap Reverse Lights -qburt19
EG:
HOW TO: My auto to manual swap PICS! 56k no no.
EK: HOW TO: 96-00 Auto to Manual Swap in full detail!! (44pics)
Crank Sensor differences
Crank Sensor Pin-out
@unix4linux there is some good info in these threads that should answer some of your wiring questions. I have my harness off the engine at the moment, so if you need pics of anything specific I can go get them later when I’m home.
Formerly unix4linux
Thanks! I'll start looking through these
21 - 27 of 27 Posts
