1 - 5 of 5 Posts
im installing a switch to cut power to the fuel pump. some thing like a theft deterent. do any of the ecu/wire gurus know what ecu wire i can splice into to get this to work. it for my ep. i want to be cut power to the fuel pump. jus another layer of protection.
Super Moderator
Waste of time IMO....... I've recovered cars that were stolen and they come prepared for situations like this. A single wire from the Fuel pump to a 12v in the fusebox will help the assholes get around that.... You have to get much more clever than that...
Super Moderator
Ok so then if you have this in place, there is no need to disable the Fuel pump since the ECU controls the fuel pump as well.
lol. if you got that already, why need to put a switch in the fuel pump circuit? well if you really want to, just put a switch inline on the feed line. just go to the fuel pump and trace the harness.
1 - 5 of 5 Posts
