I ran a welded differential in my b16 tranny on my Bseries..Is it possible to weld the diff on my kseries swap????I run an 03 type S..
Yes you can...11sec CR-X said:I ran a welded differential in my b16 tranny on my Bseries..Is it possible to weld the diff on my kseries swap????I run an 03 type S..
Could you explain the dangerous part....thnxTeamPacman said:Yes you can...11sec CR-X said:I ran a welded differential in my b16 tranny on my Bseries..Is it possible to weld the diff on my kseries swap????I run an 03 type S..
I'll rather have a LSD over Welded Diff anyday....
Welding a Diff is very Dangerous for daily or race application...
Good luck.... :wink:11sec CR-X said:Oh you think I street the car... nah this is a race only trailer car...so was the rex for awhile....But thnx for the input....I will truely consider the Quaife..
I have seen a guy do this before it was kind of funny but sad too...fearless_dsm said:if you have a clutch with extreme clamp load,and let go too quick in a turn,you will snap an axle(or two)
is quaife really that much better than stock LSD? I was planning on replacing the stock LSD with quaife but someone told me its a waste of $$ to do thatTeamPacman said:Good luck.... :wink:11sec CR-X said:Oh you think I street the car... nah this is a race only trailer car...so was the rex for awhile....But thnx for the input....I will truely consider the Quaife..
Quaife is the way to go....
adirondackR said:is quaife really that much better than stock LSD? I was planning on replacing the stock LSD with quaife but someone told me its a waste of $$ to do that
going all motor (thanks for the input pacman 8) )TeamPacman said:adirondackR said:is quaife really that much better than stock LSD? I was planning on replacing the stock LSD with quaife but someone told me its a waste of $$ to do that
Are you going all motor or turbo???
Then stock is fine...adirondackR said:going all motor (thanks for the input pacman 8) )
sorry 4 hijack - will the 6-speed LSD fit in the 5-speed K box?TeamPacman said:Then stock is fine...adirondackR said:going all motor (thanks for the input pacman 8) )
