Ok, I am going to move this and lock it. I am positive it is not their fault.
Terminology.... People refer to motor, longblock, shortblock, powertrain and they don;t always mean the same thing... Same with harness. The engine harness, the pnp harness etc... What you refer to as a subharness, we normally refer to as the charging harness or pnp harness...
hasport sells parts to make the swap easier.. The engine harness should come with the engine or should be accounted for when putting an engine together.
Before you buy the hasport mounts you can download the directions or when you buy the mounts, the directions are inlcluded in the box. In there, it says clearly the K series engine harness should be attached to the motor before dropped in the car.
I am sorry but this is the second time I read your post.. Not sure if it was here or honda tech or wherever... BUT THIS IS 100% YOUR FAULT. WHAT DID YOU THINK< THE MOTOR WILL RUN WITHOUT AN ENGINE HARNESS? WHAT ABOUT THE SPARK PLUGS? SHOULD THOSE BE INCLUDED TOO?
sorry if I come off as a jerk but I am not.. What you are complaining about here, is on you.. that is all...
If I order parts to built my own computer and when everyhting comes in, I am missing a case, I am not going to flame Newegg.com but myself. Hasport is not selling a complete Kit that includes everything. They also assume common sense.
