i heard that the 5 lug runs a 36mm axle nut, which is the same as the rsx so you can use stock k20 axles.6spd EG said:i have a 95 hatch with 5lug conversion and im using the hasport civic/k20 axles, axles are differnt from b series so i would get the hasport's there made for the swap and there really nice axles , anything hasport kicks ass!
yeah, so you cant run dc5 axles on the drivers side>?fasterthenU said:you can not use the rsx axles on both sides, the pass side you can use if you have the typeR sus. but the drivers side you need to make the axle.. OEM is much betetr...
you can still use the axle but you have to change out the shaft to dc2allmtrallday said:yeah, so you cant run dc5 axles on the drivers side>?fasterthenU said:you can not use the rsx axles on both sides, the pass side you can use if you have the typeR sus. but the drivers side you need to make the axle.. OEM is much betetr...
ok. gotcha. thanks.taqman15 said:you can still use the axle but you have to change out the shaft to dc2allmtrallday said:yeah, so you cant run dc5 axles on the drivers side>?fasterthenU said:you can not use the rsx axles on both sides, the pass side you can use if you have the typeR sus. but the drivers side you need to make the axle.. OEM is much betetr...
