41 - 45 of 45 Posts
It is an efficient motor, but I've talked about using the A8 block and a K20A2 or K20Z3 head combination. It won't have any issues if correctly build. See here: Building a K24A8/K20A2 Hybrid | Honda / Acura K20a K24a Engine Forum
Okay, thanks bro, I appreciate you’re guidance and willingness to help me out :) I’ll show my stuff! Follow the build or check it out on my gram @Evil_Guate (if I’m allowed to drop that here?)
97 civic HX K24a
Will I have an problems running proper VTEC? Isn’t the A8 an efficiency motor, I heard somewhere that it doesn’t have an oil port for VTEC accusation (I’m still new to all of this.)
The way the pistons are designed in the k24a4 and a8 causes valve contact when you crossover to the vtec lobe. You’ll either need to clearance the pistons for this, or use different ones like oem tsx, or crv spec.
Oooo okay! I understand now! Thanks so much for clearing this up for me! So if I get 30mm cranks and slap a k20a2 head on, I’ll be fine? But I bet there’s more to it than just that
97 civic HX K24a
The pistons are the only part of the block that isn’t compatible with the type s or tsx or k20z3 head. If you have a k24a1 (crv) or k24a2 (tsx) the head Swap is a direct bolt on. So if you Change the pistons in the a4/a8 it is very useable as long as you don’t over rev the engine, the cylinder head is designed for a lot more rpm than the block was. Keep in mind for a type s cylinder head you would use the crv k24a1 head gasket. For a k20z3 or k24a2 cylinder head you use the tsx k24a2 head gasket.
41 - 45 of 45 Posts
