did try this a few months back, and although it worked, the resolution is just not there to use the MAP sensor alone and using the TPS had some very undesirable effects, (I know Hondata have released newer versions since then, so this may well have improved).alanb said:
EFI although hard work to initially get the configuration right, is a way more flexible option, for starters, you can define what tables you want to use, how big/small they are, what interrelationship there is between them, etc etc etc. big learning curve, but worth it, and it costs nothing like the Motec stuff (and I think it's more flexible).
jon v said:
yes, 100%...LHP said:
I have seen them fitted up with the integra PS pump, they are not even close.
Also, 48 is not the max, we have used 51mm, and can go bigger, but have not reached the limits of 48 yet (48 is a shit big TB, unless you shooting for over 300 *real* Bhp, they are not going to be streached).
