1 - 10 of 10 Posts
Ive used search, but nothing came up.
What is the correct torque spec for crank pulley bolt? In some sources I found 181lbf-ft with torque wrench, but in the manual for my vehicle FN2 K20Z4 (and for some other's like RSX) there is different method - 36lbf-ft plus additional 90 degrees, and apparently the later is lower torque spec which is around 111lbf-ft.
Which one is correct?
102979
I would follow the service manual for your engine.
I have never accurately torqued a crankshaft pulley bolt. I always just stick my breaker bar on it, go about a foot out, then put about all of my weight on it. Used the same method on my K20 and K24, never had any issues.
97 civic HX K24a
A buddy of mine does all his motors with a 1/2”
Impact and just holds a few seconds on the crank pulley bolt. I’ve never used this method as I’m scared to F my crank threads up, but it’s always worked for him Having built 30-40 k and b/d series engines.
The higher torque spec only applies if you use a new crankshaft/bolt, I'm guessing it's to stretch the bolt initially. If you're reusing the bolt/crank, just follow what they recommend. 36lb/ft + 90*
I’m guessing its ok to use impact gun to remove it instead of breaker bar? I know it could be difficult to crack it and sometimes cheater bar must be used. Also my mate at work has 540nm air impact gun - will it do the job without damaging nothing internally?
I've used an impact in the past.
However, I tried my Milwaukee M18 impact rated for 1400 lb ft (1900 nm) and it wouldn't break one loose. I was amazed that it wouldn't.
97 civic HX K24a
You need a weighted socket my friend. I had a similar problem with my dewalt 1/2” that’s rated 1100 ft lb. tried over and over with nothing. Buddy brought the weighted 19 over and zipped it clean off without hesitation. It’s like a $25 socket but it’s designed for crank pulley removal.
97 civic HX K24a
If you get a weighted socket that should work. They are super tough to break loose with a bar. You’ll probably have to put a pipe on your breaker bar otherwise.
1 - 10 of 10 Posts
