1 - 9 of 9 Posts
Ok well I was putting my 03 type S engine harness on my tsx motor..
well the CPS is same color wiring but in different order..
anyone care to elaborate.. :up:
also the plugs don't fit!!
litterbox said:
You need one from a type S. I ran into the same problem.
so I just swap sensors??
cant I use the tsx one ??
just change the wires..
If I were you I'd test to see if you could just swap over the sensor plugs and rewire. That'd save alot of us trouble. I just ordered a type S CPS without even examining the situation. :eek:
goldywang said:
i just cut the plugs and matched the wires...didnt get a code at all. i just soldered it and it seems fine rather than buying a new sensor. I couldnt figure out how to depin the plug so i just cut.
nice hopefully I can do that also soon.
:up:
thanks for the reply :up:
Discussion Starter · #9 ·
H2nr said:
You dont have to cut the wires. you can use a safety pin to pick the pins loose.
Yes I was looking at it today. Since I had a type S swap before, I took both CPS sensors they physically look different from each other!!! I should have took pictures but anyways just fyi.
1 - 9 of 9 Posts
