41 - 51 of 51 Posts
Discussion Starter #42
2002-2005 Honda Civic Si CorSport Endlinks v2
CorSport Adjustable Endlinks | Version 2 of our Suspension to Sway Bar End Links
female side:
The housing, shaft and ball are Stainless Steel for excellent environmental resilience.
Ball joint cavity is filled with high wear lubricant Neoprene dust cover helps to protect ball joint from contaminants and debris.
Male side:
Low carbon steel, plated and yellow dichromate treated for superior corrosion resistance.
The ball joint cavity is filled with high wear lubricant.
Hardware is stainless and zinc plated for added durability.
Features:
NEW smaller design
NEW stronger design
NEW lighter weight design
NEW non-binding rotation for adjustments
NEW sealed joints design
And as always corrosion resistance
Thanks,
CorSport
41 - 51 of 51 Posts
