21 - 40 of 51 Posts
Discussion Starter #21
02-05 Civic Si CorSport Aluminum Shifter Bushings Package
02-05 Civic Si CorSport Aluminum Shifter Cable Bushings
This aluminum shifter bushing kit will help to tighten the feel of your shifter by eliminating the stock rubber bushing in the shift cable where it connects to the transmission, these are sometimes referred to as "under hood shifter bushings".
After time, the stock rubber and metal sleeved bushing will wear and deteriorate, making the shifter feel less precise and slowing down your shifting times!
These precision machined performance aluminum solid bushings give you back your shifters feel, they enable very tight and crisp shifting.
*Note: Includes Bushings, Clips and Pins. The installation is simple, and takes less than 30 minutes.
Click Here for Install Instructions
Click Here for Picture of Item Installed
02-05 Civic Si CorSport Aluminum Shifter Base Bushings
These aluminum spacers replace the rubber bushings that provide the basis for the excess movement in the shifter mechanism. By simply replacing the rubber with aluminum you create a much more exact and precise shift. It increases the overall feel of the shifter mechanism noticeably.
Note: It's a very simple install that takes a little patience and calm hands. Shipped out with instructions, also available as a .pdf file upon request.
This Contains a Full Set of 8 Bushings
CorSport USA.
Discussion Starter #23
CorSport K-Series Spark Plug Cover
CorSports spark plug covers take looks to the next level, an affordable one. Avalable in glossy black or gun metel grey. Each cover is also engraved with a corsport logo on the back so you know you are getting 100% authentic cor parts without having to see a logo.*
Features:
Easy install.
Makes your engine bay look clean
Reflective surface is perfect if you like shiny things.
All hardware is included.*
Fits 02-05 civic Si, 02-06 RSX, 04+ TSX, 06-11 Civic Si
Adds visual power, thats better then horsepower
100% USA made part
CorSport USA.
Discussion Starter #25
CorSport USA.
21 - 40 of 51 Posts
