1 - 20 of 27 Posts
Find H&R parts for your car here
H&R All Cars Category
Click here to see these products in our catalog and check out the most current pricing.
Sport Spring kits are H&R’s number one selling product. Enhance the look of your vehicle with a reduced fender well gap. H&R Sport Springs lower the vehicle center of gravity and reduce body roll for better handling. The progressive spring rate design provides superb ride quality and comfort. A lower wind resistance signature will make the vehicle more streamlined and improve gas mileage. If you are only looking to improve one part of your vehicle’s suspension, you cannot go wrong with installing Sport Springs. Fun to drive, H&R Sport Springs are the number one upgrade for your vehicle.
CorSport USA.
Discussion Starter #4
02-05 Honda Civic Si H&R Sport Adjustable Front Sway Bar - 26mm
H&R Sway Bars
Industry’s strongest and most durable.
H&R Sport Sway Bars are designed for drivers who desire improved handling without lowering or affecting ride quality. H&R Sport Sway Bars increase your suspension’s roll stiffness—or its resistance to roll in turns—while maintaining ride comfort and dramatically increasing cornering control, lateral stability, and grip. A unique feature of H&R Sport Sway Bars are the smooth, machined-like forged ends that, for specific vehicles, allow for adjustability in stiffness—giving you an unmatched level of precision and performance.
Reduces body roll
Highest tensile strength available
2 hole adjustable
H&R Sport Sway Bars are crafted from a special (hf) 50CrV4 steel alloy—the highest tensile strength available. The quality of the material and design guarantees smooth transitional sway bar function—decreasing the feedback response time—and increases stiffness over stock. H&R Sport Sway Bars improve a vehicle’s lateral stability and cornerning grip, while reducing body roll.*
H&R Sport Sway Bars are precision engineered—designed and manufactured to be strong, resilient, and durable. Adhering to the same manufacturing philosophy as H&R’s world-renowned springs, H&R Sport Sway Bar design and production receives significant attention to detail and commitment. Each sway bar is cold-formed and heat-treated, with forged seamless bar ends. H&R shot-peens the sway bars to increase durability and check for dimensional correctness. At H&R’s ISO9001 certified manufacturing facility in Germany, production is completed in-house and each sway bar must pass a series of rigorous quality control tests to earn H&R’s approval and yours.*
Being 100% German made means a commitment to doing it right—giving you the best quality product.
CorSport USA.
Discussion Starter #5
02-05 Honda Civic Si H&R Sport Rear Sway Bar - 20mm
H&R Sway Bars - Only vehicles with factory swaybar
Reduces body roll
CorSport USA.
Discussion Starter #8
02-03 Honda Civic Si H&R TRAK+ Wheel Spacers DRS - 10mm
H&R Trak+ 10mm DRS Wheel Adaptor Bolt 4/100 Center Bore 56.1 Stud Thread 12x1.5 - Sold In Pairs
Wider is Better! H&R TRAK+® Wheel Spacers provide simple and effective vehicle track widening for improved handling, performance, safety, and a 'perfect stance'. Featuring a 'perfect fit' hubcentric design, TRAK+® Wheel Spacers are extremely durable and lightweight thanks to a proprietary aluminum/magnesium alloy.
Everything you need to know about measuring, finding applications, purchasing, and installing TRAK+® Wheel Spacers is available right here at trakplus.com.
Widen vehicle track with TRAK+® Wheel Spacers
'Perfect fit' hubcentric design
Durable lightweight aluminum/magnesium alloy
Affordable and easy to install
Studs Included with DRS:
CorSport USA.
Discussion Starter #11
02-05 Honda Civic Si H&R Sport Springs
H&R Sport Springs
Superb ride quality
Lowers:
Front: 2.0"
Rear: 2.0"
CorSport USA.
Discussion Starter #14
06-11 Honda Civic Si Coupe H&R Street Performance Coil Overs
Originator of true coil over suspension for the street.
Recognizing a demand for premium suspension components tuned for the street—with race car features like adjustable lowering—H&R engineers rose to the challenge. Received in the market with great success, H&R Coil Overs feature an innovative mono-tube gas shock construction. Using premium quality materials, H&R engineers fine-tune each coil over shock with a progressive rate spring to ensure better handling and premium ride comfort.*
Each vehicle specific coil over has a fully threaded, custom shock—allowing for adjustable vehicle height. Vehicle lowering is altered using easy to adjust spring seats. Adjustable lowering accommodates summer and winter conditions and allows you to dial in the perfect ride height to fit your personal style. H&R coil overs are designed for performance, comfort, and durability using only the best components. For those drivers looking for refined suspension and a little German style, look no further than our diverse range of coil over applications.
H&R Street Performance Coil Overs are the perfect suspension solution for discerning drivers—from daily drivers to serious tuners—who can appreciate the awesome handling and superb ride comfort. Each coil over shock is custom valved to work in conjunction with a precision-engineered progressive rate spring, creating a finely tuned suspension system. The fully threaded shock body allows for adjustable vehicle height. This feature helps balance vehicle weight, resulting in a lower center of gravity and improved performance and control.
Fine tune lowering to what you want
Height adjustable
Front: 1.25-2.0"
Rear: 1.25-2.8"
CorSport USA.
Discussion Starter #15
05-06 Acura RSX H&R Sport Springs
H&R Sport Springs
Superb ride quality
Lowers:
Front: 1.4"
Rear: 1.3"
CorSport USA.
Discussion Starter #18
04-05 Honda Civic Si H&R TRAK+ Wheel Spacers DRS - 15mm
H&R Trak+ 15mm DRS Wheel Adaptor Bolt 5/114.3 Center Bore 64.1 Stud Thread 12x1.5 - Sold In Pairs
CorSport USA.
Discussion Starter #20
CorSport USA.
1 - 20 of 27 Posts
