First time here.. Need a piece of advice.
Setup is k24a2.
I am trying to have a cooling adapter on my oil filter passage.. like the k20 and the k20a2. where the hose runs to the block heater water passage..Now I seen the k24a3 and the k24a1 crv with type s/r swap.. they had to drill that block heater water passage because the block was cast.. now on the k24a2 it has a plate covering that area.. just wondering if anyone had open that plate before and see if it is already pre drilled.. and my other question.. where should i run my return coolant line to?? :?:
Setup is k24a2.
