Connecting rod measurement calcualtion for an inquire - please help!
Hi folks,
I just have a few question to you, as it will get my first K-series engine build
. I listed below my calculation table and with my question to it (unit is zoll and mm in brackets).
This is for a destroked K24 with a new F22C1 crankshaft (part # 13310-PZX-A01) and stock K20A2 head. The the piston will be new and customized, so I have to fix values for the block for now and adapte evtl. negative claying results via head gasket thickness or machining of the piston later on.
Thanks in advance for your help.
Hi folks,
- Compr. Height 1.181 (30.00)
- Big End width 0.935 (23.75) according to http://www.k20a.org/forum/showthread.php?t=70447
- Big End bore 2.008 (51.011) to 2.0088 (51.024) according to ACL bearings
- Pin End bore 0.8664 (22.01) according to http://www.k20a.org/forum/showthread.php?t=70447
- Pin End width 0.780 (19.81) according to http://www.k20a.org/forum/showthread.php?t=70447
- Rod C-t-C 6.098 (154.88)
- Piston-t-Deck -0.045 (-1.14) according to Nyborg post #6, there are also recommendations of -0.030 to -0.060 in other engine forums
- Decking -0.005 (-0.13)
- Gudgeon pin offset 0.034 (0.87) - took this value from a stock K24A3 piston. Are there any different recommendation on that?
- Deck height 9.114 (231.50)
- Stroke 3.571 (90.70)
