1 - 4 of 4 Posts
Will be ordering a new clutch soon since the stock clutch wont be able to hold the power I will soon be adding. the plan is to run 100-150hp nitrous shot on my current setup which is already making 230ish whp. Looking at close to 400whp all said and done. Keep in mind this is NOT a daily driver but will still be street driven probably once or twice a week once the weather gets a lil better. Will obviously be seeing the track as well quite a bit.
Looking around, I've found that Hybrid has the best prices on the Competition clutches, so this is what i'll be going with. That's where the question comes in. Stage 4 and 5 are the same price. stg 4 is the 6 puck, and stage 5 is a 4 puck. How much difference is there in the drivability? Should I go with the 4 or 5? Sprung or unsprung for this setup?
I think the stage 4 will work for you. I will be making power around the same, im going with the Stage 5.
IF you end up needing info on your setup and which clutch, contact
Competition directly:
[email protected]
800-809-6598
They will help you. Melissa is my contact. If you call or email... ask for her or Chris, tell them Ben Howard sent you for info.
1 - 4 of 4 Posts
