Free Shipping to the Continental 48 states.
Competion Clutch Kits now availeable at ASP.
Working hand in hand with Competion Clutch, we are able to bring you the best prices and on time shipping.
2400
Stage 1 - Gravity Series 2400 Clutch Kit
The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel. 300 mile break-in recommended with this set-up.
DO NOT use with added forced induction such as turbo, supercharger, or NOS systems.
The 2400 Series kit includes a Competition Clutch pressure plate, a 6 pad Carbotic high-torque performance disc assembly, all applicable bearings and the appropriate alignment tool.
2100
Stage 2 - Street Series 2100 Clutch Kit
This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 mile break-in REQUIRED with this set-up.
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
2300
Stage 3 - Street/Strip Series 2300 Clutch Kit
This segmented Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up.
The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Kevlar facings, all applicable bearings, and the appropriate alignment tool.
1680
Stage 3 - IronMan Street/Strip Series 1680 Clutch Kit
This assembly features our advanced hybrid iron and carbon friction material riveted to our high torque disc assembly in a six puck style. The IronMan provides outstanding stability, smooth engagement, and less wear on opposing surfaces. Offers 175% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 1680 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Iron/Carbon buttons, all applicable bearings, and the appropriate alignment tool.
1620
Stage 4 - Strip Series 1620 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
0620
Stage 4 - Strip Series 0620 Clutch Kit
This assembly, available with a six puck rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 0620 Series kit includes a performance pressure plate, a six puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
1420
Stage 5 - Strip Series 1420 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 1420 Series kit includes a performance pressure plate, a four puck high torque sprung disc Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
0420
Stage 5 - Strip Series 0420 Clutch Kit
This assembly, available with a rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 0420 Series kit includes a performance pressure plate, a four puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
Race Series Twin Disc Assembly
Competition Clutch provides the most economical racing clutch for the active sport compact enthusiast and is the preferred assembly for the professional racer. We currently offer our 4140 Forged Steel Flywheel with this unit to ensure durability in extreme racing conditions.
The CCI Twin Disc delivers uncompromised reliability and performance. All assemblies are plug and play with no additional modifications required in the transmission. Guaranteed to provide simplicity in installation and inexpensive component repair and replacement.
Acura RSX
02-08 8037-2100 2.0L (6 spd) Type S - SCC Stage 2 - Carbon Kevlar 4 K20
02-08 8037-1620 2.0L (6 spd) Type S - SCC Stage 4 - 6 Pad Ceramic 4 K20
02-08 8037-0620 2.0L (6 spd) Type S - SCC Stage 4 - 6 Pad Rigid Ceramic 4 K20
02-08 8037-1420 2.0L (6 spd) Type S - SCC Stage 5 - 4 Pad Ceramic 4 K20
02-08 8037-0420 2.0L (6 spd) Type S - SCC Stage 5 - 4 Pad Rigid Ceramic 4 K20
02-08 8037-1680 2.0L (6 spd) Type S - SCC Ironman - 6 Pad Iron 4 K20
02-08 TW-8037-CER 2.0L (6 spd) Type S - TWIN DISC CERAMIC KIT 4 K20
2400
2100
2300
1680
1620
0620
1420
0420
Acura RSX
