1 - 11 of 11 Posts
Banned
Hey i just finished installing a competition stg 4 clutch with 11.5 fly wheel on my 06 rsx. The car drives fine but the clutch engages really low. I have the pedal practically slammed to the floor and as soon as i start to let off its starting to engage. Is there anyway to adjust this???
IMAKEBOOSTATIDLE
behind the pedal is a rod...with a nut on it...untighten it. then move the rod to adjust the engagement. then tighten it back up.
Just about avery stage 4 clutch I have installed requires a washer to be placed behind the throwout pivot ball regardless of pedal adjustment.
Since we started adding them as a routine when installing the stage 3 and 4 pressure plates we have had ZERO issues with blown hydraulics and low pedal engagement.
These clutchs have a shorter installed height that the hydraulics can not fully compensate for.
I have used this procedure and it has worked great for me.
never heard of that, course I am new to this. What does it do, make engagement higher? I am running a stage 2 pressure plate with a stage 4 clutch, I have the ironman one. Reason is I ruined the stage 2 due to being first stick car. Would I benefit any from this? Mine engages bout 3/4way out though, so would there be no benefit?
It is for use with stage 3-4 pressure plates for the most part. I have yet to see the issue with a stage2 pressure plate.
what does it do? Would it help the issue I have of disengaging the clutch before I am fully into gear like I do from time to time, actually seldom now, but use to be alot.
It will move the engagement point from right at the floor to the middle of the pedal stroke. This may help your issue, if your hand/foot timing is off a bit, or you dont fully depress the clutch pedal.
as often as I seem to be taking my tranny out, I will try this for a few races to see how it does, thanks. Cause I do have timing issues.
1 - 11 of 11 Posts
