1 - 20 of 23 Posts
Cometic Head Gaskets
About Cometic Head Gaskets
Custom gaskets has given top engine builders worldide the confidence needed for sealing today's performance engines. Cometic's state-of-the-art manufacturing techniques, along with their wide range of materials provide the latest in gasket technology at an affordable price regardless of the level of competition.
For the Sport Compact World Cometic offers gaskets in MLS (Multi Layer Steel) for the best possible seal at the best possible price. Gasket Material:
MLS: (Multi Layer Steel)
The Cometic MLS gasket is comprised of three layers of Stainless Steel. Cometic uses Stainless steel for increased strength, it's ability to rebound and corrosion resistance.
CorSport USA.
Discussion Starter #10
Honda/Acura K20/K24 86MM Cometic Head Gasket
Honda K20/K24 86MM .030" Cometic Stock Head Gasket Replacement
Cometic Gasket's 15 years of experience in shelf stock and custom gaskets has given top engine builders worldide the confidence needed for sealing today's performance engines. Cometic's state-of-the-art manufacturing techniques, along with their wide range of materials provide the latest in gasket technology at an affordable price regardless of the level of competition.
The outer layers of the gasket are embossed and coated on both sides with a flouroelastomer rubber based material (Viton) designed to meet the demands of a variety of harsh sealing environments, load conditions and surface finishes. The Viton coating is heat resistant to 2500C or 4820F.
The center or shim layer of the gasket is comprised of an uncoated Stainless Steel layer, which can be varied to accommodate multiple thickness requirements. The MLS gasket is ideal for both aluminum heads to cast iron blocks and aluminum heads to aluminum blocks. The composition of MLS will also withstand the shearing forces created by aluminum heads on cast iron blocks. No re-torque is necessary.
By design the MLS gasket promotes an even torque load across the sealing surface allowing for measurable reduced bore distortion.
OTHER BORES (86mm, 87mm, 88mm and 89mm Bores) and OTHER THICKNESSES (.027, .040, .030, .045, .051, .074, .120) AVAILABLE with a small wait time, please specify when ordering if you want another size combination.
CorSport USA.
Discussion Starter #13
Honda/Acura K20/K24 89MM Cometic Head Gasket
Cometic*Head Gasket Replacement*Honda K20/K24 89MM .036"*MLS Head Gasket
OTHER BORES (86mm, 87mm, 88mm and 89mm Bores) and OTHER THICKNESSES (.027, .040, .030, .036, .045, .051, .074, .120) AVAILABLE with a small wait time, please specify when ordering if you want another size combination.
CorSport USA.
1 - 20 of 23 Posts
