1 - 4 of 4 Posts
Ok here is the deal. When I push the clutch pedal all the way down I can hear a whining/grinding noise and its kind of hard to get into gear. But when I go to push the clutch pedal to about 90 to 95% down there is no noise and I can shift fine into every gear. NOW it wont go into any gear. Before this happened the clutch felt great no slipping at all and the tranny felt fine. Its an A2 tranny w/ LSD and CC stage three clutch. Thanks
yea last time I had problems like this it was a broken clutch disk. check the obvious first as mentioned by DR!
Discussion Starter #4
Found the problem. Pulled the tranny off today and found one of the springs that popped off the clutch disk.:down::down::down:
1 - 4 of 4 Posts
