1 - 6 of 6 Posts
hey guys, im having clutch problems with my eg.
93' EG hatch
k20a 6spd
i have a steel braided line with an fittings for my clutch. every so often i loose all my clutch fluid. this happened twice to me. after the first i cut the line a lil bit thinking maybe i had a hole in the line or something. that wasnt it, it still leaked all out. with that second time i switched out the clutch slave with a brand new one, and yet again it happened. all this happening within a month time span. and jus the other day i felt it loosing pressure again and sure enough i was low on fluid and had to fill it again. anyone know about this bein a frequent problem? and also, should i jus swap out the hole line?
Look under you dash and see if your master is leaking. Look at the clutch pedal and see if its wet.
Any updates?
hey guys, as an update, i took the car out tonight. checked the resivour before driving and it was low so i filled it up. i did check the pedal, the medal leg part had some wetness to it as well as the black piece that goes into the firewall, and also i felt some wetness from the bottom of my an fitting that goes into the slave. is it possible the line and the master need to be replaced?
Super Moderator
Yes. It needs replacing.
1 - 6 of 6 Posts
