I used a hardline ( # 14 in schematic below ) from the stock D series motor. It attaches right to the rubber line from the K.special K said:what have you used for a new clutch line?
how long?
thanks
I was thinking of doing the same till i saw that they are both 5/8th" cylinders. It looks as though the bolt holes will line up, but the RSX CMC may be slightly cocked to the right.dapretendr said:i think ima try to use the rsx's clutch MC and lines seems like a beter CMC design. hoffuly it has the same bolt pattern as civic's
