1 - 2 of 2 Posts
Here is the story, first this swap has been in my car for three years and never had a problem with anything. This is what happen, I was doing a little run with a buddy of mine, and after the run we went to do one more and as I was down shifting the cluster just died. The car runs fine. The whole cluster is dead, tach, speedo, gas and water gauge, all the dummy lights are dead. I also lost my clock and blinkers, but the hazards work. Head lights work and the illumanation lights on the cluster work. I went to check the fuses but I lost the clear fuse chart so I just started checking every fuse and found a blown 10a and replaced it and nothing changed. The car is a eg with a A2 swap with a AEMems and a hybrid under dash harness. I need to find the problem because I'm going the Import Face Off this sunday. Any help will be great.
Discussion Starter #2
bump
1 - 2 of 2 Posts
