1 - 10 of 10 Posts
? why get one piston, what is wrong with what you will be setting up with? I am assuming your running stock pistons? You wont damage the piston by claying the motor, but I would install the pistons normal, that way you get a more accurate reading and dont scratch the walls up. And I am not an expert, but I would think your safe for 50* cam advance, no claying needed, unless your upping compression. Chris off CRSX mentioned he has yet to see very many cams want 50* so I bet you prob wont benefit past 40* on these.
1 - 10 of 10 Posts
