1 - 15 of 15 Posts
if the fitting is to go into a prop valve, you want the inverted flare (like the end of the fitting pictured to the right)
if the fitting is to go into an -AN fitting, you want the 37* flare (the first fitting to the left)
the bubble flare protrudes out like so (pictured on the right)
Ok. I know AN fittings require a 37* flare - I'm good in that area.
so are inverted and bubble the same? unless i am retarded, you said the fitting on the right is both inverted and bubble.
Off Jegs:
Bubble
Inverted
Thanks for your help so far! :up:
my apologies, i made an error
you are right, the second image you have posted does show the inverted flare.
inverted is what you want.
thanks... do you happen to know if bubble is used on any of the oem ports such as the wheel well bulkheads?
thanks!
Discussion Starter · #8 ·
bubble isnt used at all on honda's
just double 45 on the brake line itself
and the inverted flare on the fitting.
i think bubble is used on domestic vehicles but someone correct me if i'm wrong
Thanks!
I'm looking to put adapter fittings in the prop valve to 3an tube nuts/sleeves with 3/16 line. just want to make sure i get the right stuff!
like this:
1 - 15 of 15 Posts
