1 - 5 of 5 Posts
Hey guys,
Just would like to know what the benefits are of upgrading the oil pump on my Accord Euro & if it's worth while doing? I've read something about it increasing power & that it is suitable for high RPM applications but is it really necessary?
I also found a link to a kit but wasn't quite sure if it would be a direct fit to my motor.
http://afhkparts.com/shop/kswap-honda-parts/k20-rsx-type-s-oil-pump-kit"]http://afhkparts.com/shop/kswap-honda-parts/k20-rsx-type-s-oil-pump-kit/"]http://afhkparts.com/shop/kswap-honda-parts/k20-rsx-type-s-oil-pump-kit
Hey guys,
What other mods are you planing to install ?
You will get 3-5 hp :)
That kit will fit, but read instruction how to install
Installed on my engine:
You should really look into getting an RRC oil pump instead of an Type-S (A2/Z1) pump because the RRC pickup scoop is taller/deeper (in the pan) and is native use for the RBC/RRC oil pan.
The type-S pump has a shallower pickup scoop and is native use to the PRB oil pan.
you can't use an RRC pump with a PRB pan either, cuz the scoop will bottom out on the floor of the PRB pan because of the taller scoop.
RRC pump to RBC/RRC pan
PRB pump to PRB pan
You'll want to stick with an RBC/RRC pan if you have a real CL7 vehicle because a torque mount is integrated into mounting to those pans, where it is not on an RSX, EP3 civic, or k-swapped legacy chassis's (ie. 88-91 civic/90-01 integra).
· USDM > *
PRB pump to PRB pan
As usual...good info:up:
1 - 5 of 5 Posts
