Hey fellas I'm working on dropping a 07 k24a2 into a 2000 civic 4dr. Question is I used the search bar and only found one example on Honda-tech explaining how to Modify the charge harness. I didn't fully understand what the guy did and wanted to know if anyone had a couple pictures or a write up on K20a.org of what needs to be cut and soldered. If you have approximate lengths on what wires need to be extended?
I'm using an 04 rsx type S harness, 07 tsx charge harness. Does any plugs need to be changed on the Type S wire harness to work with the K24a2? or vise versa any sensors on k24a2 motor need to be changed to work with Type S wire harness?
Also the white thick wire on the charge harness was cut on one side not sure if its to alternator or starter can that be fixed or extended? what piece was cut off?
Thanks everyone for the help.
Chris
Chris
