Hi,
I took out my s2000 cluster to see what it looks like back there and debating if I want to go back to stock cluster of my 1992 Civic Si.
I put it back, plugged in the harness and all was OK.
I started the car multiple times and it started up fine BUT at the end of the engine turning on there was this noise as if you would turn the key all the way until you hear the crank noise but in my case I didn't hold the key open if that makes sense.
Then after a few more times I turned the car on to try and figure out what that cranking noise was, the car would die.
Typically, I would wiggle both battery wires and then for whatever reason the power would come back. I know this because I kept the key in the ignition.
If I pulled the red wire up and hold it there, I would hear the beep from ignition. If the red wire goes back down, the power is cut.
But now, with the key in the ignition and no matter how I position the red, no power at all.
Tried turning my corner lights on but nothing and my brakes don't work either.
I'm thinking it's a dead battery, correct? The only reason I question this is because of that weird crank noise when the car was able to turn on so I'm thinking it's the starter as well?
Thanks for your advice.
