Started stripping the back of the car to prep for engine removal
EMS out
trunk panels out, exhaust out
That was a few days ago - it's been way to hot to work in my driveway, so I've been taking care of the yard work/landscaping that needed attention.
Today I started putting the replacement block together. Hone, new rings, new rod bearings. $525 for the machine work/rings/ ring gapping/bearing clearance checks, etc.
Block on the stand
removed the galley plug for the RSX oil pump block off
nice clean crank
Pistons assembled on rods, ready to go in block. He marked each per cylinder he fitted them for to make my life easier
pistons & rods installed (drop of oil on rings to help install), assembly lube on bearings & crank in, lube on rod cap bearings, caps torqued (2 stages, 25ft/lb then 120º)
hondabond for carrier plate, 10 mains bolts oiled & torqued in sequence; two stages (22ft/lb, then 56º). 14 M8 bolts torqued in sequence to 16 ft/lbs (or wast it 11ft/lbs, I've forgotten already)
Hopefully I'll get the drivetrain out the car tomorrow
EMS out
Block on the stand
nice clean crank
