Is it possible to put an RSX Type S motor into a 93-97 Del Sol
1\4 mile time you can do 13's depending on driver and engine of choice, but you gotta remember that the del sol is heavier(2400lbs -\+ Correct me if im wrong) and most times you see on here are in the hatches. Suspension you should not worry about, because the k series is around 25 lbs -\+ then the B series engines. But its an investments. i got about 2000.00 left in parts to get my ek hatch running. And i will be runnin a type-S.K20ADELSOL said:Does anyone have n e other pics/specs of the Type S in the del sol? What would it run 1/4 mile? or any supension problems?
