1 - 3 of 3 Posts
I've read a few posts regarding the coating on these cranks some people say they should not be ground etc.
The main crank journals show a small amount of wear I'm assuming this is normal?
the Rod ends on 1 and 3 have the most wear and I think these would need to be polished out/machined if that is doable?
Have included pictures, hoping for some advice.
Rod ends could this be residual bearing?
Lotus Elise K20A2
The mains look OK, the rod journals are shot. Either get a good used crank or have them reground to match oversized bearing shells.
you may give them a slight polish with polishing paste and a shoe string before final judgement.
thanks, I will make some calls this week to see about regrinding.
1 - 3 of 3 Posts
