jon v said:
Umm, I don't think so. Go check out some of the ITR's on H-T that are boosting on stock blocks. They won't boost more than 8PSI, well at least the smart ones won't. amd they are making in the 300-350whp range. If I am correct, which I am thats a nice 100-150 hp gain. Higher compression more power you make per a pound of boost. So ou can make the same power on an ITR boosted as you can on a GSR boosted at much lower boost preasures...
I don't want to argue with you cuz you do have very good points.
Ok I overexaggerated on the 20 hp gain, yes higher compression with low boost can give you great results along with a lot of low end to compensate turbo lag. However, this needs perfect tuning and I also think its power is limited unless you do change out the pistons and cams which sux cuz u just paid a butt load for your motor. I never said it couldn't be done, but the point I really wanted to make is its not
as reliable. I said as instead of "it is" so you don't say "but so and so...." If you tune your car on a 80 degree day what about a 90 degree day, what if the place your at doesn't have 93 octane, what if its humid, very small margin of error on high compression turbo cars. Look at the JRSC boosted ITR on hondata.com (i know its not turbo but its boosted). I say only do it if its going to be your toy car and not your daily driver. I remember someone on another message board always said you can only pick two from these 3: cheap, fast, reliable.
