1 - 12 of 12 Posts
NOTE: Im in canada, willing to ship, let me know a Zip and ill get a quote
1994 Civic EX Coupe (US Model)
• ABS Pump and brake lines
• ABS module
• (anything you need from the ABS system let me know… ive got everything you need, plus ill give you a manual for the car on CD so you know how to wire it up… LOL)
• Power Steering Rack
EG Civic
• RPM Cluster with tach
• B-series mounts for EG (I think I have them all, ill check if inquired)
• B-series shift linkage into EG *free short sifter*
• Tokico Illumina rear shocks with skunk2 coilovers
• Stock front shocks
• One front Skunk2 Coilver (other one free, sleeve is cracked)
• 02 Sensor for older Civics 4-wire
1995 Civic DX
• Cylinder Head (almost anything you need)
• Crank
• Rods
• (Random stuff from the longblock, ask)
2003 Accord 2.4L
• Cylinder Head (no camgears or holders)
• Intake Mani
• Exhaust Manifold (upper)
• Powersteering pump
• AC compressor
• Pistons/Rods -
• EGR system
RSX type S
• intake manifold
• Clutch/Flywheel/Pressure Plate (needs to be resurfaced, like $50 anywhere)
-Chipped P30 ECU B18 VTEC 8500 RPM
-02 Sensor for older Accords 4-wire
-B-series TPS
-new BLACK Ractive harness, This was featured in SuperStreet's part's guide!!!!!!!!!!!! (nicest part ive ever seen from Ractive...)
-Autogauge 4.75" (not sure, i measure OD) black face tach with shift light
- White faced water temp guage
- White faced oil temp guage
• ABS module
Will this stuff work with a 92 eg?
yes it will, it came out of a 94, so its the same idea
it might be hard to put it into a car that didnt have ABS previously, but im sure it can be done by someone qualified
make an offer
Re: Bunch of random stuff... K-series, B-series, OEM and aftermarket, EG civics, RSXs wtv
sloboy_hatch said:
how much for just the rear skunk coilovers? to 93280
i'd prefer to sell the rears together with the fronts, if not with the shocks
ill do the coilover kit with one broken coilover (just the sleeve is cracked) for $100 shipped
you will have an 2 extra springs and an extra sleeve, since the front and rear are the same thing if im not mistaken? you can use it to hold your hood open at car shows :)
Discussion Starter · #7 ·
K20DC2R said:
how much for that accord upper exhaust manifold?
i think i PMed you, ill do it for $80 shipped
Discussion Starter · #9 ·
how much for this????
hrm... maybe around 190 plus shipping... im not sure where you live shipping might be a pain if your in the states
Discussion Starter · #10 ·
bump
willing to nego if you dont like my prices
Discussion Starter · #12 ·
complete as in? its the intake MANIFOLD... it comes with just the manifold and it doesnt have a throttle body or anything...
1 - 12 of 12 Posts
