1 - 2 of 2 Posts
I was hoping to get more power out of my k24z3 [its in a 2009 Honda accord sedan] as well as more rpm and was wondering if anyone knew where to buy cams and if for example k24a cams work in it because if I look for parts to fit specifically in the k24z3 there is almost nothing same with trying to find an intake for it so I'm currently looking at putting in
K20 oil pump Now sure if I have to get a certain one for for this particular k24
Valve springs
mild cams nothing crazy
Intake manifold
headers
any help would be appreciated
92 EG k24z3 swap
Intake manifold
The K20 oil pump will work just fine after normal alteration but the k20 windage tray only bolts at 2 of 4 points.
As far as an intake, any PRB style manifold should work (youll need a coolant bypass adapter).
1 - 2 of 2 Posts
