1 - 20 of 41 Posts
Use this code for 10% off all buddy club
Also, order any header get free wrap
buy any buddy club wheel get free lug nuts
Discussion Starter #8
06-11 Civic Buddy Club N+ Spec Damper W/Upper Mounts
BRAND NEW! ALL NEW!!! "N+ SPEC DAMPER" from Buddy Club is the choice complete suspension setup with resemblance of our RACING SPEC damper's excellent attributes. It is cost effective and is well rounded for the budget minded weekend club racer. With optional urethane isolated aluminum upper mount design, engineered spring rates, 15 level damper adjustability, and ride height adjustment capabilities, the N+ SPEC DAMPER can accommodate any driver's preferences.
With over 15 years of competitive racing experience, you can trust that your car will perform the way you want it to with quality components from Buddy Club.
Vehicle ride height is adjusted independently of spring pre-load. With other alternatives available on the market today, vehicle ride height is adjusted by reducing or increasing the preload on the coil spring. This primitive methold leads to inconsistent spring rates that are dependent upon the vehicle ride height. With any of the Buddy Club suspension components, including the N+ SPEC, vehicle ride height is independent of spring pre-load. This method ensures that the spring rate is always consistent, no matter how high or low your car is. In addition, it ensures that the spring is always properly positioned onto the strut and effectively reduces miscellaneous and unnessary noise.
15 Level Adjustment
Suspension adjustability is a key element when selecting a top quality coil-over system. The N+ SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).
The shock-body is constructed out of cadmium plated steel and is finished with beautifully anodized precision CNC machined aluminum ends. Urethane bushings are used when applicable to ensure a top quality product.
In a complete suspension setup, the coil-spring is a very key element. The coil-springs used on all Buddy Club suspension setups are specially made to exacting specifications by Buddy Club engineers. Each coil spring is manufactured to exacting tolerances to ensure performance in every demanding situation.
To ensure that the N+ SPEC Dampers stay looking superb through your years and years of ownership, each precision CNC machined aluminum component is beautifully burgandy anodized and each steel component is cadmium plated for corrosion resistance. Great attention to detail was taken to ensure that you will be completely satisfied with your ownership of Buddy Club components.
This bearing seat is developed based on data acquired from various competitions and racing experience. It is a brand new design in order to prevent the vibration noise of the spring on the Macpherson systems. It will increase the overall performance of the suspension by decreasing the twisting tension between the spring and the damper.
CorSport USA.
Discussion Starter #10
02-06 Acura RSX Buddy Club RS EVO Damper Kit
The Triple adjustable Racing Spec Evo Damper is the new evolution from our Racing Spec Damper.It features 15 positions of high speed bump adjustment and 15 positions in rebound also features an additional 6 positions of low speed bump adjustment.The low speed bump adjuster is very effective in helping to control body roll while adding to turn in and is effective in controlling pitch and squat Integral reservoir contains increased nitrogen volume for more consistent damping over a long race.
CorSport USA.
Discussion Starter #12
Buddy Club P1 Racing SF Challenge Wheels 17X7.0 4X100 ET42 Matte Black/Red (Set Of 4)
Buddy Club P1 Racing SF Challenge Wheels -*17X7.0 4X100 ET42
P1 Racing SF wheels are offered with budget minded racers in mind. When every ounce counts, the P1 Racing SF does not disappoint with its light weight design. In the same lineage of the legendary forged P1 Racing QF Wheel, the SF continues in the same manner, offering lightweight quality and high-performance. The P1 Racing SF wheel is a perfect strike of style and performance while making it durable enough for both track and street duties.
AVAILABLE COLORS:
Matt Black W/Red Lip
Matt Black W/Yellow Lip
White W/Red Lip
White W/blue Lip
CorSport USA.
Discussion Starter #13
Buddy Club P1 Racing SF Challenge Wheels 17X7.0 4X100 ET42 White/Blue (Set Of 4)
AVAILABLE COLORS:
White W/Red Lip
White W/blue Lip
CorSport USA.
Discussion Starter #14
02-05 Civic Si Buddy Club P1-Racing Camber Kit (Rear)
Buddy club P1-RACING camber kit is specially designed for double-A suspension.
Sophisticate design makes alignment more accurate. With the camber angle adjustment, the car will be more stable on the straight and has better control in the corner. The camber kit is made of light weight high strength materials with precise manufacture process.
With many years of racing experience and numerous testing, The camber kit has extremely good performance and quality.
How about Buddy Club P-1 Racing Camber kit better than other product?
The center section of the general camber kit is the weakest area; it could easily be distorted when the locking screw is tightening too hard.
Buddy Club Camber kit use the special reinforced solid design which dramatically increase the strength of the camber kit.
By using low profile joint, the P1-racing camber kit provides 5mm more clearance between the top of the camber kit and bottom of the strut tower. The low profile joint also featires cadmium plating for additional corrosion resistance.
Standard camber kit does not have the reinforcement in the center area which can cause distortion when tightening the locking screw too hard or under severe stress. This may lead to accident or damage to other components on the vehicle.
CorSport USA.
Discussion Starter #19
CorSport USA.
1 - 20 of 41 Posts
